64 Bit driver digital signature
Messagede oh6mqm » Sam 8 Oct 2011 13:31
Hello
64 bit SAA driver to win 7 is not installed correctly.
It is missing digital signature.
I have tried to pass it withbout succes.
How i should continue ?
oh6mqm
Re: 64 Bit driver digital signature
Messagede F6DZP » Lun 31 Oct 2011 06:04
it is not a problem specific with this driver, but you have same problem with all drivers without digital signature.
it's a Win7 (and Vista) problem often encountered.
You must find how to install it with administrator rights.
I have not tested with Win7 64bits, only with Win7 32 bits, sorry.
My next PC will be with Win7 64 bits.
Messagede oh6mqm » Dim 11 Déc 2011 21:33
F6DZP a écrit:it is not a problem specific with this driver, but you have same problem with all drivers without digital signature.
Hello
Just for info Technotrend Data drivers do not either install
itself to Win7 64
oh6mqm
Messagede F6DZP » Ven 16 Déc 2011 11:06
on this page they confirm that BDA driver is Win7 64 bits compatible:
http://www.tt-pc.com/2959/PC_Products.html
But I have not tested yet with win7 64 bits.
I can just say that Saa7146a 32bits driver or BDA driver works under Win7 32 bits
I don't know if other people have tested.
Messagede g3gja » Ven 20 Avr 2012 08:52
I too have tried without success to make the drivers install in a Win 7 64bit environment. Installing with admin rights does not help; I've tried with local admin and Domain admin (my home PC is on my work corporate Domain) rights.
I have to dual boot with Win XP sp3 32bit to use Tutioune which is annoying as all my current programs & work on in the Win7 64bit.
Clive G3GJA / G8EQZ
g3gja
Messagede oh6mqm » Ven 20 Avr 2012 13:02
g3gja a écrit:I too have tried without success to make the drivers install in a Win 7 64bit environment. Installing with admin rights does not help; I've tried with local admin and Domain admin (my home PC is on my work corporate Domain) rights.
Clive G3GJA / G8EQZ
Hello .
I have similar experience. Does not work on in 64Bit system.
I amd also running dual system for that reason
Br. Esko Petäjä
OH6MQM
oh6mqm
Messagede F6DZP » Sam 19 Oct 2013 15:50
Tutioune can work well under Win7 64 bits
Several OM use Tutioune under Win7 64 bits. There are solutions.
I know Win7 is sometimes hard to accept software/driver not "Microsoft certified".
I have no PC with Win7 64 bits for the moment ( only several PC under Win7 32 bits and Win XP - double boot).
I will install one Win7 64 bits and Win8 64 bits ASAP to test and find the easiest solution for the driver installation.
Messagede F6DZP » Lun 21 Oct 2013 13:43
it's done!
Tutioune works well on my PC with WIN7 64 bits.
All is explained here:
viewtopic.php?f=72&t=255
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 18 invités
