Tutioune Audio
Messagede vk6mj » Jeu 21 Nov 2013 12:53
Hi all...this question of mine may have been answered elsewhere and I will continue to look for it. However, I now have Tutioune working with my S2-1600 card and currently I have configured a prime focus 1.2 mtr dish with a local Australian Satellite lnb tuned to one of the free to air channels from OPTUS-D1. The picture is very very nice however I cannot hear the audio. I have looked all over my windows 7 setup but just don't see the audio going anywhere. Tutioune shows the Video PID = 00516 and the Audio PID = 00654.
Can anyone suggest a fix please?
Regards from downunder.
Martin VK6MJ
vk6mj
Re: Tutioune Audio
Messagede F6DZP » Jeu 21 Nov 2013 22:01
hello,
what is the station you want to receive? (to check the audio codec used: if it is AC3 or AC3+ you need to install AC3 audio decoder. win7 can only decode mpeg audio)
you can install LAV and check with "checkmatos v4.2" if you can hear audio from TS file I provide.
LAV will also add AC3 codec.
http://www.vivadatv.org/viewtopic.php?f=72&t=262
http://www.vivadatv.org/viewtopic.php?f=60&t=261
You can also try to send TS via UDP to VLC and see if VLC can decode audio.
Re: Tutioune Audio
Messagede vk6mj » Jeu 21 Nov 2013 23:42
Thanks everyone...I have solved the problem. I seet the Auto Pid to off, and scan mode to Next Channel and selected Station2
Regards
Martin
vk6mj
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 10 invités
