problem with TiouneVideo_V05d.exe
Messagede steinway » Mar 15 Oct 2013 00:34
Shows gray screen or blue screens and I have to shut down. S2-1600 and Amd 64. I am too far into this to go back. Seems I will need specific instructions all the way thru.
steinway
Re: C:\TUTIOUNE\TiouneVideo_V05d.exe
Messagede F6DZP » Mar 15 Oct 2013 14:53
How! this is very difficult to answer.
This software is old and is used to receive station after having set and receive the TS using Tutioune (Tutioune1600 in your case) and after having leaving Tutioune.
As I don't how you have proceed first, I cannot answer.
After installation, try first to run :
- verifMatos to be sure your card and driver is well installed
and after :
Tutioune1600 V0.3a
check if your GRAPH square LED at right is Green, not red.
you can find it for download here : viewtopic.php?f=60&t=214
and explanation here : viewtopic.php?f=61&t=235
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 21 invités
