Can someone help me I am new to all of this and have installed the software and get all green lights and on test minitouner it is 98% when I run the software no picture no decode and the TS section are always RED Lights never Green no Bitrate. I have a 75 ohm cable going from my tiouner to the satellite dish do i need something like a pre amp on RX antenna for DATV. I have an Adalm pluto and it works fine on QO-100. I am only using a standard 80cm Dish but not been able to see one transmission. Thanks for your time any help would be appreciated.
Steve
MM0SAJ
DLL version: 3.2.16
we have found 2 device(s)
device 0:
device serial N° DA5O38MPA
device named: MiniTiouner_Pro_TS2 A
For NIM I2C, we will use this device
FT2232H NIM_I2C is open
OK, we will use it with Handle: 9085400
device 1:
device serial N° DA5O38MPB
device named: MiniTiouner_Pro_TS2 B
For TS2 transfer, we will use this device
FT2232H FIFO open for TS2
OK, we will use it with Handle: 9083056
FT2232H FIFO closed for TS2
USB driver version: 2.12.36
>>>>>>>>>> NO MiniTiouner-Pro connected to USB AUX! <<<<<<<<<<<
****************** NIM I2C controler INIT *******************
NIM_I2C controler INIT OK
OK MPSSE is empty
Init MPSSE NIM I2C done!
MiniTiounerPro/Pro2 detected
TS1 led is OFF
TS2 led is OFF
MiniTiounerPro2 detected
LNB A detected at 0v
LNB B detected at 0v
NIM Test
I2C repeater OFF
Reset Demod
Demodulator Address = $D2
we get the value = 81
Demodulator is a STV0910A
NIM is a SERIT_FTS4335/FTS4334L
MiniTiouner-Pro with NIM Serit FTS-4334 detected
Repeater mode OFF
writing a value at address X seems OK
trying to read 1000 times register X
time to do it : 531msec
we have : 0 reading errors from 1000
test: 512 writing/reading the Demodulator
we have : 0 writing errors and 0 reading errors from 512
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
STV0910 Demodulator setup
Writing demodulator default values ==> OK
time to do it: 500msec
STV0910 Init done
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
------ LNA booster detection ------
LNA found by reading the value : 33
2nd LNA found by reading the value: 33
writing $5A at address X seems OK
we try to do 1000 readings of register X after demodulator init
time to do it : 594msec
test: 512 writing/reading the Demodulator after initialization
Init Serit FTS-4335/34 ZeroTuner
ZeroTuner initialization ==> OK
Reading values in STV6120 registers
Reading STV6120 is OK
TS1 led is ON
TS2 led is ON
END Test NIM
TS1 led is ON
TS2 led is ON
TS1 led is ON
TS2 led is ON
LNB A voltage set at 18v
LNB B voltage set at 18v
Home
